Ir para o conteúdo principal
Sony Vaio SVE171C11L Hard Drive Replacement
O que você precisa
  1. Sony Vaio SVE171C11L Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L Hard Drive Replacement: passo 2, imagem 1 %32
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L Hard Drive Replacement: passo 3, imagem 1 %32
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L Hard Drive Replacement: passo 4, imagem 1 %32
    • Pull the battery away.
  5. Sony Vaio SVE171C11L Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two screws that secure the hard drive cover.
  6. Sony Vaio SVE171C11L Hard Drive Replacement: passo 6, imagem 1 %32 Sony Vaio SVE171C11L Hard Drive Replacement: passo 6, imagem 2 %32
    • After the screw have been removed, pop the hard drive cover open.
  7. Sony Vaio SVE171C11L Hard Drive Replacement: passo 7, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the 3 screws that secure the hard drive.
  8. Sony Vaio SVE171C11L Hard Drive Replacement: passo 8, imagem 1 %32
    • When finished removing the screws, use your fingers to hold the blue ribbon attached from the hard drive to remove it from laptop
Conclusão
Edward Briseno
Membro desde: 09/26/22
893 Reputação
Autoria de 6 guias
Equipe
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Membro de CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 241
