Introdução
If you need to new the display screen, use this guide to properly take out the old screen and install the new screen. This guide will have moderate difficultly and will take around 30 minutes. You will need a plastic opening tool and a Phillips #0 screwdriver head to complete this guide.
O que você precisa
Use a Phillips #00 screwdriver to remove the two screws that secure the hard drive cover.
There are two hinges that connect the display to the body of the laptop
Unscrew two 9mm screws and two 4mm screws that are on both hinges.
