Ir para o conteúdo principal
Sony Vaio SVE151G11L Speaker Replacement
O que você precisa
  1. Sony Vaio SVE151G11L Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE151G11L Speaker Replacement: passo 2, imagem 1 %32
    • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
  3. Sony Vaio SVE151G11L Speaker Replacement: passo 3, imagem 1 %32
    • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
  4. Sony Vaio SVE151G11L Speaker Replacement: passo 4, imagem 1 %32
    • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
  5. Sony Vaio SVE151G11L Speaker Replacement: passo 5, imagem 1 %32
    • Pull battery away from laptop.
  6. Sony Vaio SVE151G11L Speaker Replacement, Hard Disk Drive: passo 6, imagem 1 %32
    • Flip laptop over so the bottom is facing upwards.
  7. Sony Vaio SVE151G11L Speaker Replacement: passo 7, imagem 1 %32
    • Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
  8. Sony Vaio SVE151G11L Speaker Replacement: passo 8, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 8, imagem 2 %32
    • Pop open the cover to the HDD.
  9. Sony Vaio SVE151G11L Speaker Replacement: passo 9, imagem 1 %32
    • Remove the screws on the HDD with a Phillips #000 screwdriver.
  10. Sony Vaio SVE151G11L Speaker Replacement: passo 10, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 10, imagem 2 %32
    • Pull plastic tab away from the laptop.
    • Lift HDD away from laptop.
  11. Sony Vaio SVE151G11L Speaker Replacement, Speakers: passo 11, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement, Speakers: passo 11, imagem 2 %32 Sony Vaio SVE151G11L Speaker Replacement, Speakers: passo 11, imagem 3 %32
    • Remove the back cover.
  12. Sony Vaio SVE151G11L Speaker Replacement: passo 12, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 12, imagem 2 %32
    • Remove 4 hinge screws with a Phillips #0 screwdriver.
  13. Sony Vaio SVE151G11L Speaker Replacement: passo 13, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 13, imagem 2 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 13, imagem 3 %32
    • Pop open hinge.
    • Remove black screw size P000.
  14. Sony Vaio SVE151G11L Speaker Replacement: passo 14, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 14, imagem 2 %32
    • Remove wiring along its guide.
  15. Sony Vaio SVE151G11L Speaker Replacement: passo 15, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 15, imagem 2 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 15, imagem 3 %32
    • Remove two hinge screws size P00.
    • Pop open hinge.
  16. Sony Vaio SVE151G11L Speaker Replacement: passo 16, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 16, imagem 2 %32
    • Remove black screw.
  17. Sony Vaio SVE151G11L Speaker Replacement: passo 17, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 17, imagem 2 %32
    • Remove secondary black screw.
  18. Sony Vaio SVE151G11L Speaker Replacement: passo 18, imagem 1 %32
    • Remove speaker.
  19. Sony Vaio SVE151G11L Speaker Replacement: passo 19, imagem 1 %32 Sony Vaio SVE151G11L Speaker Replacement: passo 19, imagem 2 %32
    • Follow wire down its wire channel and remove it from the channel.
    • Pull up on the connector to disconnect the speakers to the motherboard.
  20. Sony Vaio SVE151G11L Speaker Replacement: passo 20, imagem 1 %32
    • Remove speaker and wire from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Theg
Membro desde: 10/15/18
758 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 Membro de UMass Dartmouth, Team S9-G9, Valliere Fall 2018
UMASSD-VALLIERE-F18S9G9
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 415
