Ir para o conteúdo principal
Sony Vaio SVE15112FXS LCD Screen Replacement
O que você precisa
  1. Sony Vaio SVE15112FXS LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS LCD Screen Replacement: passo 2, imagem 1 %32 Sony Vaio SVE15112FXS LCD Screen Replacement: passo 2, imagem 2 %32 Sony Vaio SVE15112FXS LCD Screen Replacement: passo 2, imagem 3 %32
    • Slide the "lock" tab upward to unlock the battery before removal.
    • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
  3. Sony Vaio SVE15112FXS LCD Screen Replacement: passo 3, imagem 1 %32
    • Turn the computer back over and open the lid.
    • Remove the four rubber screw covers at each corner of the screen to expose the bezel screws
  4. Sony Vaio SVE15112FXS LCD Screen Replacement: passo 4, imagem 1 %32
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screen bezel screws in each corner.
  5. Sony Vaio SVE15112FXS LCD Screen Replacement: passo 5, imagem 1 %32 Sony Vaio SVE15112FXS LCD Screen Replacement: passo 5, imagem 2 %32
    • Insert a plastic opening tool between the bezel and laptop lid. Work it around the edge to loosen the bezel.
    • Lift the bezel outward to remove it and expose the screen.
    • Take care when using the spudger near the hinges to avoid breaking the bezel.
  6. Sony Vaio SVE15112FXS LCD Screen Replacement: passo 6, imagem 1 %32 Sony Vaio SVE15112FXS LCD Screen Replacement: passo 6, imagem 2 %32
    • Use a #0 Phillips screwdriver to remove the four 3.0 mm screen screws.
    • Cover the keyboard with a cloth or towel to protect the screen and keep any broken glass out of the keyboard.
  7. Sony Vaio SVE15112FXS LCD Screen Replacement: passo 7, imagem 1 %32 Sony Vaio SVE15112FXS LCD Screen Replacement: passo 7, imagem 2 %32 Sony Vaio SVE15112FXS LCD Screen Replacement: passo 7, imagem 3 %32
    • Pull the screen toward you and away from the lid until a silver cable behind the screen is visible.
    • Remove the silver cable from the back of the screen. It is glued at the top and the bottom.
    • Do not pull the cable loose from the lid, only remove it from the back of the screen.
  8. Sony Vaio SVE15112FXS LCD Screen Replacement: passo 8, imagem 1 %32 Sony Vaio SVE15112FXS LCD Screen Replacement: passo 8, imagem 2 %32 Sony Vaio SVE15112FXS LCD Screen Replacement: passo 8, imagem 3 %32
    • Lift the barcode label on the back of the screen upward to loosen the screen cable connector.
    • Once the connector is visible, remove it from the pins on the back of the screen.
  9. Sony Vaio SVE15112FXS LCD Screen Replacement: passo 9, imagem 1 %32
    • Lift the screen toward you to remove it completely from the lid.
Conclusão
Uma outra pessoa concluiu este guia.
Ashley Bierman
Membro desde: 09/06/18
1.223 Reputação
Autoria de 5 guias
Equipe
Ohio State, Team S1-G1, Whitney Fall 2018 Membro de Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 793
