Ir para o conteúdo principal
Sony Vaio SVE15112FXS Keyboard Replacement
O que você precisa
  1. Sony Vaio SVE15112FXS Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Keyboard Replacement: passo 2, imagem 1 %32
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Keyboard Replacement: passo 3, imagem 1 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 3, imagem 2 %32
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Keyboard Replacement: passo 4, imagem 1 %32
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Keyboard Replacement: passo 5, imagem 1 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 5, imagem 2 %32
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Keyboard Replacement: passo 6, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the one 4.0 mm screw next to the model number label.
  7. Sony Vaio SVE15112FXS Keyboard Replacement: passo 7, imagem 1 %32
    • Use a plastic opening tool to slide the CD-ROM out from the laptop.
  8. Sony Vaio SVE15112FXS Keyboard Replacement: passo 8, imagem 1 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 8, imagem 2 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 8, imagem 3 %32
    • Slide the "lock" tab upward to unlock the battery before removal.
    • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
  9. Sony Vaio SVE15112FXS Keyboard Replacement: passo 9, imagem 1 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 9, imagem 2 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 9, imagem 3 %32
    • To unsecure the back cover, remove all the case screws using a #0 Phillips screwdriver.
    • Remove the two 9.0 mm screws on each side of the battery.
    • Remove the twelve 8.0 mm long screws alongside the entire back cover.
    • Remove the three 3.0 mm screws inside the battery well.
  10. Sony Vaio SVE15112FXS Keyboard Replacement: passo 10, imagem 1 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 10, imagem 2 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 10, imagem 3 %32
    • Use a plastic opening tool to carefully pry open the latch points located under the silver plastic trim. Repeat this around the back cover.
    • It may be easiest to start around the CD-ROM bay because there is more room.
    • To avoid damaging the plastic trim and cover, do not force difficult areas and make sure the opening tool is completely under the black plastic cover, not just the silver trim.
    • Lift the back cover upward and away from the laptop.
  11. Sony Vaio SVE15112FXS Keyboard Replacement: passo 11, imagem 1 %32
    • Gently push the rectangular opening on the CD-ROM well to loosen the keyboard.
  12. Sony Vaio SVE15112FXS Keyboard Replacement: passo 12, imagem 1 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 12, imagem 2 %32
    • Use a plastic opening tool to pry upward on the keyboard. Only the top of the keyboard is latched.
    • Lift the keyboard toward you and away from the laptop.
  13. Sony Vaio SVE15112FXS Keyboard Replacement: passo 13, imagem 1 %32 Sony Vaio SVE15112FXS Keyboard Replacement: passo 13, imagem 2 %32
    • Use a plastic opening tool to disconnect the two ZIF connectors attached to each ribbon. Both are located under the keyboard and have a clear flap that must be lifted upward before removal.
    • Open the white connector attached to the copper ribbon.
    • Open the white connected attached to the black and white striped ribbon.
    • Take care when opening these connectors. The ribbon is anchored underneath the clear flap. Pulling these pieces out of their sockets will make it difficult to reassemble them.
    • Lift the keyboard away from the body of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Ashley Bierman
Membro desde: 09/06/18
1.223 Reputação
Autoria de 5 guias
Equipe
Ohio State, Team S1-G1, Whitney Fall 2018 Membro de Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 444
