Ir para o conteúdo principal
Sony Vaio SVE15112FXS Hard Drive Replacement
O que você precisa
  1. Sony Vaio SVE15112FXS Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 2, imagem 1 %32
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 3, imagem 1 %32 Sony Vaio SVE15112FXS Hard Drive Replacement: passo 3, imagem 2 %32
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 4, imagem 1 %32
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 5, imagem 1 %32 Sony Vaio SVE15112FXS Hard Drive Replacement: passo 5, imagem 2 %32
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Hard Drive Replacement: passo 6, imagem 1 %32 Sony Vaio SVE15112FXS Hard Drive Replacement: passo 6, imagem 2 %32
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screws attaching the mount to the hard drive.
    • Slide the hard drive away from the mount until it is completely detached.
    • Take note of how the mount is positioned when attached to the hard drive.
Conclusão
Uma outra pessoa concluiu este guia.
Ashley Bierman
Membro desde: 09/06/18
1.223 Reputação
Autoria de 5 guias
Equipe
Ohio State, Team S1-G1, Whitney Fall 2018 Membro de Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 751
