Ir para o conteúdo principal
Sony Vaio SVE111B11L Motherboard Replacement
O que você precisa
  1. Sony Vaio SVE111B11L Motherboard Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio SVE111B11L Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Motherboard Replacement: passo 2, imagem 1 %32
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Motherboard Replacement: passo 3, imagem 1 %32
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Motherboard Replacement, Keyboard Assembly: passo 4, imagem 1 %32
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Motherboard Replacement: passo 6, imagem 1 %32
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Motherboard Replacement: passo 7, imagem 1 %32 Sony Vaio SVE111B11L Motherboard Replacement: passo 7, imagem 2 %32 Sony Vaio SVE111B11L Motherboard Replacement: passo 7, imagem 3 %32
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
  8. Sony Vaio SVE111B11L Motherboard Replacement, Fan: passo 8, imagem 1 %32
    • Locate the fan and heat-sink.
  9. Sony Vaio SVE111B11L Motherboard Replacement: passo 9, imagem 1 %32
    • Locate the wires and connectors, and gently unplug them.
  10. Sony Vaio SVE111B11L Motherboard Replacement: passo 10, imagem 1 %32
    • Locate and remove the 6.7 mm screws that hold the fan assembly.
  11. Sony Vaio SVE111B11L Motherboard Replacement: passo 11, imagem 1 %32
    • Gently lift the fan assembly up and out.
  12. Sony Vaio SVE111B11L Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Take the covers on the bottom of the laptop off.
  13. Sony Vaio SVE111B11L Motherboard Replacement: passo 13, imagem 1 %32
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  14. Sony Vaio SVE111B11L Motherboard Replacement: passo 14, imagem 1 %32 Sony Vaio SVE111B11L Motherboard Replacement: passo 14, imagem 2 %32 Sony Vaio SVE111B11L Motherboard Replacement: passo 14, imagem 3 %32
    • Locate the wires and connectors and remove them from the motherboard.
  15. Sony Vaio SVE111B11L Motherboard Replacement: passo 15, imagem 1 %32 Sony Vaio SVE111B11L Motherboard Replacement: passo 15, imagem 2 %32
    • Lift the mother board out and safely put it to the side.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
i have the same laptop, and i mistakenly remove the mother board cmos battery , and is not recognizing my laptop system hard drive.
in this case what can i do in other to restore it back.
onyebuchiadieze - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 1,972
