Ir para o conteúdo principal
Sony Vaio SVE111B11L Fan Replacement
O que você precisa
  1. Sony Vaio SVE111B11L Fan Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio SVE111B11L Fan Replacement, Battery: passo 1, imagem 2 %32
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Fan Replacement: passo 2, imagem 1 %32
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Fan Replacement: passo 3, imagem 1 %32
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Fan Replacement, Keyboard Assembly: passo 4, imagem 1 %32
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Fan Replacement: passo 5, imagem 1 %32
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Fan Replacement: passo 6, imagem 1 %32
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Fan Replacement: passo 7, imagem 1 %32 Sony Vaio SVE111B11L Fan Replacement: passo 7, imagem 2 %32 Sony Vaio SVE111B11L Fan Replacement: passo 7, imagem 3 %32
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
  8. Sony Vaio SVE111B11L Fan Replacement, Fan: passo 8, imagem 1 %32
    • Locate the fan and heat-sink.
  9. Sony Vaio SVE111B11L Fan Replacement: passo 9, imagem 1 %32
    • Locate the wires and connectors, and gently unplug them.
  10. Sony Vaio SVE111B11L Fan Replacement: passo 10, imagem 1 %32
    • Locate and remove the 6.7 mm screws that hold the fan assembly.
  11. Sony Vaio SVE111B11L Fan Replacement: passo 11, imagem 1 %32
    • Gently lift the fan assembly up and out.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
There are missing steps. For example - after removing keyboard assembly, there are 4 screws under it.
Keyboard assembly is not ment to be removed in way showed in pictures. There are melted plastic tabs to keep top cover in place. By prying that, you will broke them and top cover will not be possible to put back as before.
Only keyboard itself should be removed by prying it out, starting from bottom (thoucpad). Top of keyboard has larger “ears“ and they are hooked under top cover.
Gundars Pinka - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 30
Duração total: 1,318
