Introdução
This guide shows how to replace the battery on the Sony Vaio Pro 13. Special care must be taken when handling Lithium-Ion batteries, avoid puncturing or bending the battery pack. Always recycle your old battery pack according to your local regulations.
O que você precisa
Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
Remove the two rubber feet at the back of the computer, these can be removed in the same way.
Once the bottom cover is removed, peel away the piece of tape located near the fan and heat sink assembly.
7 outras pessoas executaram este guia.
