Ir para o conteúdo principal
Sony Vaio Pro 13 Bottom Cover Replacement
O que você precisa
  1. Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: passo 1, imagem 1 %32 Sony Vaio Pro 13 Bottom Cover Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Remove cover for the extended battery connector. Use your finger nail or a plastic opening tool to remove it.
    • Remove the two rubber feet at the back of the computer, these can be removed in the same way.
  2. Sony Vaio Pro 13 Bottom Cover Replacement: passo 2, imagem 1 %32 Sony Vaio Pro 13 Bottom Cover Replacement: passo 2, imagem 2 %32
    • Remove the four 5.6mm Philips #00 screws located at the top of the computer.
    • Remove the eight 3.6mm Philips #00 screws on the base of the computer.
  3. Sony Vaio Pro 13 Bottom Cover Replacement: passo 3, imagem 1 %32 Sony Vaio Pro 13 Bottom Cover Replacement: passo 3, imagem 2 %32
    • Using a plastic opening tool, pry the plastic casing away from the base of the computer, the remaining clips around the edges can be released using your hands.
    • Leave the side with the USB and audio port until last, then slide the case out and off, so the audio port doesn't get caught.
Conclusão
7 outras pessoas executaram este guia.
Um comentário
Hi…I have same laptop, what your advice getting the cover back on? especially near the audio and usb ports…that my hang up
thanks
chrisrai - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 6,993
