Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If the display is damaged and does not function properly, you should remove it and get it repaired or replaced.
CAUTION: Static electricity in your body can ruin you computer. Use an anti-static wristband.
O que você precisa
The battery is located on the left side of the laptop, as shown by the red circle.
Make sure the laptop is disconnected and turned completely off.
Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
Use tweezers to remove the rubber covers on the four screws at the corners near the display.
Using a spudger or another flat-headed tool, start to pry away the front bezel panel from the display assembly. While putting pressure on the front bezel, place the spudger on the seam connecting the front and rear bezel, and the clip attaching the two panels should start to come apart.
