Ir para o conteúdo principal
Sony Vaio PCG-F360 RAM Replacement
O que você precisa
  1. Sony Vaio PCG-F360 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 RAM Replacement: passo 2, imagem 1 %32
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 RAM Replacement: passo 3, imagem 1 %32
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 RAM Replacement: passo 4, imagem 1 %32
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 RAM Replacement, Keyboard: passo 5, imagem 1 %32 Sony Vaio PCG-F360 RAM Replacement, Keyboard: passo 5, imagem 2 %32 Sony Vaio PCG-F360 RAM Replacement, Keyboard: passo 5, imagem 3 %32
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 RAM Replacement: passo 6, imagem 1 %32 Sony Vaio PCG-F360 RAM Replacement: passo 6, imagem 2 %32 Sony Vaio PCG-F360 RAM Replacement: passo 6, imagem 3 %32
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 RAM Replacement: passo 7, imagem 1 %32 Sony Vaio PCG-F360 RAM Replacement: passo 7, imagem 2 %32
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
  8. Sony Vaio PCG-F360 RAM Replacement, RAM: passo 8, imagem 1 %32
    • Slide your RAM into the housing by aligning it with the plastic, tan colored, guides until it is firmly in place.
    • The computer in the picture only has the standard 64 MB of on-board RAM. This RAM is not removable from the motherboard, but additional RAM can be added.
Conclusão
ahintz
Membro desde: 04/21/10
28 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 16-3, Maness Spring 2010 Membro de Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,699
