Ir para o conteúdo principal
Sony Vaio PCG-F360 Floppy Drive Replacement
  1. Sony Vaio PCG-F360 Floppy Drive Replacement, Battery: passo 1, imagem 1 %32
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Floppy Drive Replacement: passo 2, imagem 1 %32
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Floppy Drive Replacement: passo 3, imagem 1 %32
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Floppy Drive Replacement: passo 4, imagem 1 %32
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: passo 5, imagem 1 %32 Sony Vaio PCG-F360 Floppy Drive Replacement, Floppy Drive: passo 5, imagem 2 %32
    • With one hand slide and hold the tab shown.
    • With your other hand, pull the floppy drive out of the floppy drive bay.
    • To replace the floppy drive, simply slide the drive into the slot until it clicks.
Conclusão
ahintz
Membro desde: 04/21/10
28 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 16-3, Maness Spring 2010 Membro de Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 2,779
