Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The 14.1" VGA display can be removed as a whole and replaced.
O que você precisa
Position the laptop screen-side down as shown.
In this position the battery housing will be located on the right hand side.
There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
Remove the six screws along the hinges (three on either side).
Twist and pry at the hinge covers with a spudger until they pop up and remove them.
