Introdução
If you have not fixed your problem through our Troubleshooting Guide, then you may have to replace your Hard Drive.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged before performing any maintenance on the system.
NOTICE
Make sure your replacement hard drive is a serial ATA hard drive (SATA). Any other hard drive will be incompatable.
Set the computer display-side down.
Unlock the battery by sliding the port-side latch to the 'unlock' position.
Turn the laptop upside down.
Remove the three screws from the front mouse panel located on the bottom of the laptop.
17 outras pessoas concluíram este guia.
