Introdução
The goal of this guide is to walk you through the process of replacing the batter of a Sony Vaio VPCEG26FX Laptop step-by-step. The battery needs to be replaced if the laptop needs to be charged very frequently or cannot be used without being plugged in. Be careful of using force to remove the battery. It has a rail system that requires correct alignment to remove.
O que você precisa
Quase terminado!
Conclusão
