Ir para o conteúdo principal
Sony Vaio PCG-61411L RAM Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Sony Vaio PCG-61411L RAM Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio PCG-61411L RAM Replacement, Battery: passo 1, imagem 2 %32 Sony Vaio PCG-61411L RAM Replacement, Battery: passo 1, imagem 3 %32
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L RAM Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-61411L RAM Replacement: passo 2, imagem 2 %32 Sony Vaio PCG-61411L RAM Replacement: passo 2, imagem 3 %32
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L RAM Replacement, RAM: passo 3, imagem 1 %32
    • The RAM cards reside in the rectangle shaped plate in the center of the back panel of the device.
  4. Sony Vaio PCG-61411L RAM Replacement: passo 4, imagem 1 %32 Sony Vaio PCG-61411L RAM Replacement: passo 4, imagem 2 %32
    • Unscrew the single PH1 6mm screw at the top of the panel. The screw remains in the panel.
    • Remove the panel by lifting it towards yourself.
  5. Sony Vaio PCG-61411L RAM Replacement: passo 5, imagem 1 %32 Sony Vaio PCG-61411L RAM Replacement: passo 5, imagem 2 %32 Sony Vaio PCG-61411L RAM Replacement: passo 5, imagem 3 %32
    • To remove the individual RAM card panels, snap back the metal latches on each side of the cards.
  6. Sony Vaio PCG-61411L RAM Replacement: passo 6, imagem 1 %32 Sony Vaio PCG-61411L RAM Replacement: passo 6, imagem 2 %32
    • After pinching the metal latches, the RAM card should pop out slightly upward.
    • Remove the cards by pulling them out to the left.
    • Repeat for the second panel of RAM cards.
Conclusão
Sean Lyon
Membro desde: 03/01/18
381 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,147
