Ir para o conteúdo principal
Sony Vaio PCG-61411L Optical Disc Drive Replacement
O que você precisa
  1. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: passo 1, imagem 2 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Battery: passo 1, imagem 3 %32
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 2, imagem 2 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 2, imagem 3 %32
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 4, imagem 1 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 4, imagem 2 %32
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 5, imagem 1 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 5, imagem 2 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 5, imagem 3 %32
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 6, imagem 1 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 6, imagem 2 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 6, imagem 3 %32
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
  7. Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: passo 7, imagem 1 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement, Optical Disc Drive: passo 7, imagem 2 %32
    • Remove the 5mm screws with the PH0 screwdriver.
    • Remove the 3mm screws with the PH0 screwdriver.
  8. Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 8, imagem 1 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 8, imagem 2 %32
    • Lift the backplate from bottom right and left corner and remove it from the laptop.
  9. Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 9, imagem 1 %32 Sony Vaio PCG-61411L Optical Disc Drive Replacement: passo 9, imagem 2 %32
    • Slide your finger from the right of the optical disc and pull the optical disc from right to left.
Conclusão
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 617
