Introdução
This guide will instruct users on how to remove the keyboard from the laptop for repair or replacement purposes.
O que você precisa
Now, remove the small covers from the back of the case.
Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
Then, lift up on and remove these covers as shown in the third image.
Locate the fan (top-right corner of the computer).
Using a Phillips #00 screwdriver, unscrew the six 2.7 mm screws that secure the fan to the motherboard.
With your hand, grasp the side of the DVD/CD drive and gently pull it out of the socket, disconnecting it from the motherboard.
Using the Phillips #00 screwdriver, unscrew the two 4.9 mm screws depicted here.
Next, remove the metal cover to expose the bluetooth card.
Gently fit the flat end of a spudger under the edge of the bluetooth card. Then, lightly pry up on this edge to release the card from the motherboard. (Refer to the third image)
Using the Phillips #00 screwdriver, remove the one 3.7 mm screw that secures the keyboard to the laptop.
