Ir para o conteúdo principal
Sony Vaio VPCCW17FX Fan Replacement
O que você precisa
  1. Sony Vaio VPCCW17FX Fan Replacement, Back case: passo 1, imagem 1 %32
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Fan Replacement: passo 2, imagem 1 %32 Sony Vaio VPCCW17FX Fan Replacement: passo 2, imagem 2 %32 Sony Vaio VPCCW17FX Fan Replacement: passo 2, imagem 3 %32
    • Remove the battery by pinching the two lock tabs towards the center.
    • Next, lift up on the battery to remove it.
  3. Sony Vaio VPCCW17FX Fan Replacement: passo 3, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
    • Be sure to remove all screws, including those that are typically covered by the battery.
  4. Sony Vaio VPCCW17FX Fan Replacement: passo 4, imagem 1 %32 Sony Vaio VPCCW17FX Fan Replacement: passo 4, imagem 2 %32 Sony Vaio VPCCW17FX Fan Replacement: passo 4, imagem 3 %32
    • Now, remove the small covers from the back of the case.
    • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
    • Then, lift up on and remove these covers as shown in the third image.
  5. Sony Vaio VPCCW17FX Fan Replacement: passo 5, imagem 1 %32 Sony Vaio VPCCW17FX Fan Replacement: passo 5, imagem 2 %32 Sony Vaio VPCCW17FX Fan Replacement: passo 5, imagem 3 %32
    • Remove the hard drive.
    • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
    • Next, lift up and pull outwards to release the hard drive from its socket.
  6. Sony Vaio VPCCW17FX Fan Replacement: passo 6, imagem 1 %32
    • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
  7. Sony Vaio VPCCW17FX Fan Replacement: passo 7, imagem 1 %32
    • After proper removal of all necessary screws, gently lift up on the back case to remove it.
  8. Sony Vaio VPCCW17FX Fan Replacement, Fan: passo 8, imagem 1 %32 Sony Vaio VPCCW17FX Fan Replacement, Fan: passo 8, imagem 2 %32 Sony Vaio VPCCW17FX Fan Replacement, Fan: passo 8, imagem 3 %32
    • Locate the fan (top-right corner of the computer).
    • Using a Phillips #00 screwdriver, unscrew the six 2.7 mm screws that secure the fan to the motherboard.
  9. Sony Vaio VPCCW17FX Fan Replacement: passo 9, imagem 1 %32 Sony Vaio VPCCW17FX Fan Replacement: passo 9, imagem 2 %32
    • This step can be skipped if you are just removing the fan to access another part of the device (such as the motherboard).
    • Using a Japanese Industrial Standard #00 screwdriver, unscrew four 3.7 mm screws located on the casing of the fan.
  10. Sony Vaio VPCCW17FX Fan Replacement: passo 10, imagem 1 %32 Sony Vaio VPCCW17FX Fan Replacement: passo 10, imagem 2 %32
    • Using your fingers, grasp the white tab and firmly, yet gently, pull up on the wire to disconnect it from the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 1,010
