Ir para o conteúdo principal
Sony Vaio VGN-SR140E Hard Drive Replacement
O que você precisa
  1. Sony Vaio VGN-SR140E Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 3, imagem 1 %32 Sony Vaio VGN-SR140E Hard Drive Replacement: passo 3, imagem 2 %32
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Using a Phillips #1 screw driver, loosen both screws holding the cover in place. These screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 5, imagem 1 %32
    • Lift the cover with a fingernail or plastic opening tool from the side where the screws are present and lift it off to the left.
  6. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 6, imagem 1 %32
    • The hard drive is covered by a thin, black, plastic flap. Gently lift the hard drive up and to the right.
    • Be careful not to damage the ribbon cable during this step.
  7. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 7, imagem 1 %32 Sony Vaio VGN-SR140E Hard Drive Replacement: passo 7, imagem 2 %32
    • Use the spudger or a fingernail to carefully release the lock securing the ribbon cable to the motherboard.
  8. Sony Vaio VGN-SR140E Hard Drive Replacement: passo 8, imagem 1 %32 Sony Vaio VGN-SR140E Hard Drive Replacement: passo 8, imagem 2 %32
    • Grasp the ribbon cable carefully near the connector end. Remove it by pulling the cable away from the connector on the motherboard at a slightly upward angle.
Conclusão
Uma outra pessoa concluiu este guia.
Jeremy
Membro desde: 03/18/15
722 Reputação
Autoria de 4 guias
Equipe
Michigan Tech, Team 1-6, Lauer Spring 2015 Membro de Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 17
Duração total: 935
