Ir para o conteúdo principal
Sony Vaio VGN-SR140E CD/DVD Drive Replacement
O que você precisa
  1. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 2, imagem 1 %32
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 3, imagem 1 %32 Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 3, imagem 2 %32
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, CD/DVD Drive: passo 4, imagem 1 %32
    • Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
  5. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 5, imagem 1 %32
    • Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
  6. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 6, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
  7. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: passo 7, imagem 1 %32
    • Gently slide the CD/DVD drive out of the laptop.
Conclusão
Jeremy
Membro desde: 03/18/15
722 Reputação
Autoria de 4 guias
Equipe
Michigan Tech, Team 1-6, Lauer Spring 2015 Membro de Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 970
