Introdução
If your computer is running slowly, and other troubleshooting options are not working, you may need to replace your hard drive. This guide will walk you through how to remove your hard drive, requiring only a PH0 screwdriver.
O que você precisa
Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
The screws are held into the panel by washers, they will not fall out once unscrewed.
Uma outra pessoa concluiu este guia.
