Ir para o conteúdo principal
Sony Vaio VGN-TXN25N Keyboard Replacement
O que você precisa
  1. Sony Vaio VGN-TXN25N Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Take out the screw in the center of the computer.
  2. Sony Vaio VGN-TXN25N Keyboard Replacement: passo 2, imagem 1 %32
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  3. Sony Vaio VGN-TXN25N Keyboard Replacement: passo 3, imagem 1 %32 Sony Vaio VGN-TXN25N Keyboard Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  4. Sony Vaio VGN-TXN25N Keyboard Replacement: passo 4, imagem 1 %32 Sony Vaio VGN-TXN25N Keyboard Replacement: passo 4, imagem 2 %32
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  5. Sony Vaio VGN-TXN25N Keyboard Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-TXN25N Keyboard Replacement: passo 5, imagem 2 %32 Sony Vaio VGN-TXN25N Keyboard Replacement: passo 5, imagem 3 %32
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
Conclusão
Austen
Membro desde: 04/03/12
32 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 5-3, Forte Spring 2012 Membro de Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 2,068
