Ir para o conteúdo principal
Sony Vaio VGN-TXN25N Display Screen Replacement
O que você precisa
  1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: passo 1, imagem 1 %32 Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: passo 1, imagem 2 %32
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 2, imagem 1 %32 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 2, imagem 2 %32 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 2, imagem 3 %32
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 3, imagem 1 %32 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 3, imagem 2 %32
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 4, imagem 1 %32 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 4, imagem 2 %32 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 5, imagem 1 %32 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 5, imagem 2 %32 Sony Vaio VGN-TXN25N Display Screen Replacement: passo 5, imagem 3 %32
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Sony Vaio VGN-TXN25N Display Screen Replacement: passo 6, imagem 1 %32
    • Remove the screen.
Conclusão
Uma outra pessoa concluiu este guia.
Andrew Ricker
Membro desde: 04/04/12
71 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-3, Forte Spring 2012 Membro de Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 3,587
