Introdução
If the LCD Display Screen is black, cracked, or has colored lines running through it when the computer is on, the screen is broken. Follow these instructions on how to install a screen
Peças
Não são necessárias peças.
  1. Place the computer on a flat surface with the top facing up. Open the screen.
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Locate the rubber screw caps at the two bottom corners of the screen. Use your finger to remove the rubber screw caps. Use your finger to remove the rubber screw caps.
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Locate the two screws, one on each bottom corner. Unscrew the screws with a Phillips head size #0 screwdriver.
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  5. Use a plastic opening tool to gently lift the plastic casing that borders the screen. Pop off the casing by working the tool around the outside of it. Wiggling the tool may be required. The casing could be fitted snugly.
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  6. Carefully flip down the screen so it rests on the keyboard. Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection. Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  7. Remove the screen.
    • Remove the screen.
Conclusão
Uma outra pessoa concluiu este guia.
Andrew Ricker
71 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-3, Forte Spring 2012 Membro de Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Todo: 3,003
