Ir para o conteúdo principal
Sony Vaio PCG-4G1L Optical Drive Replacement
O que você precisa
  1. Sony Vaio PCG-4G1L Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 2, imagem 2 %32
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 3, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 3, imagem 2 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 3, imagem 3 %32
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Optical Drive Replacement, Keyboard: passo 4, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement, Keyboard: passo 4, imagem 2 %32
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 5, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 5, imagem 2 %32
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 6, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 6, imagem 2 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 6, imagem 3 %32
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
  7. Sony Vaio PCG-4G1L Optical Drive Replacement, Network Antenna: passo 7, imagem 1 %32
    • Swivel the Network Antenna up so that it points upward.
  8. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 8, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 8, imagem 2 %32
    • Pinch thumb and index finger at the Network Antenna's base.
    • Make sure not to bend the Network Antenna. Failing to do so can cause damage to the antenna.
    • Pull the Network Antenna off.
  9. Sony Vaio PCG-4G1L Optical Drive Replacement, Plastic Casing: passo 9, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement, Plastic Casing: passo 9, imagem 2 %32
    • Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
  10. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 10, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 10, imagem 2 %32
    • Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
  11. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 11, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 11, imagem 2 %32
    • Disconnect the cable by using the precision tweezers.
    • Slowly pry out the ribbon cable by using the plastic opening tool.
  12. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 12, imagem 1 %32
    • Do not pull the plastic cover too far away, as a ribbon cable is still attached. Failing to do so can cause damage to ribbon cable or the connector.
    • Remove the plastic cover by inserting the plastic opening tool around the edge.
  13. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 13, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 13, imagem 2 %32
    • Disconnect the ribbon cable by pulling straight up with your fingers.
  14. Sony Vaio PCG-4G1L Optical Drive Replacement, Optical Drive: passo 14, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement, Optical Drive: passo 14, imagem 2 %32
    • Insert the PH0.8 bit into the pin hole to eject the optical drive.
  15. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 15, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 15, imagem 2 %32
    • Remove one 4mm Phillips #0 pan head screw, using a Bit Driver with a Phillips PH000 bit.
    • Remove three 5mm Phillips #0 flat head screws, using a Bit Driver with a Phillips PH000 bit.
  16. Sony Vaio PCG-4G1L Optical Drive Replacement: passo 16, imagem 1 %32 Sony Vaio PCG-4G1L Optical Drive Replacement: passo 16, imagem 2 %32
    • Apply pressure to the ribbon cable, then pick up and pull the optical drive away from the cable.
Conclusão
Cole Collins
Membro desde: 10/04/16
175 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-3, Cagle Fall 2016 Membro de USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 586
