Ir para o conteúdo principal
Sony Vaio PCG-4G1L Keyboard Replacement
O que você precisa
  1. Sony Vaio PCG-4G1L Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Keyboard Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 2, imagem 2 %32
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Keyboard Replacement: passo 3, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 3, imagem 2 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 3, imagem 3 %32
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Keyboard Replacement: passo 5, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 5, imagem 2 %32
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Keyboard Replacement: passo 6, imagem 1 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 6, imagem 2 %32 Sony Vaio PCG-4G1L Keyboard Replacement: passo 6, imagem 3 %32
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
Conclusão
Cole Collins
Membro desde: 10/04/16
175 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 2-3, Cagle Fall 2016 Membro de USF Tampa, Team 2-3, Cagle Fall 2016
USFT-CAGLE-F16S2G3
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 723
