Ir para o conteúdo principal
Sony Vaio PCG-4121GL Wifi Board Replacement
O que você precisa
  1. Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Wifi Board Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-4121GL Wifi Board Replacement: passo 2, imagem 2 %32 Sony Vaio PCG-4121GL Wifi Board Replacement: passo 2, imagem 3 %32
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Wifi Board Replacement: passo 3, imagem 1 %32
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Wifi Board Replacement: passo 4, imagem 1 %32 Sony Vaio PCG-4121GL Wifi Board Replacement: passo 4, imagem 2 %32 Sony Vaio PCG-4121GL Wifi Board Replacement: passo 4, imagem 3 %32
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: passo 5, imagem 1 %32 Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: passo 5, imagem 2 %32
    • Lift up the two golden knobs on the left side of the WiFi board.
    • Remove the single 3mm Phillips #0 screw located on the WiFi board to the top left of the battery compartment.
  6. Sony Vaio PCG-4121GL Wifi Board Replacement: passo 6, imagem 1 %32 Sony Vaio PCG-4121GL Wifi Board Replacement: passo 6, imagem 2 %32
    • Once the screw and the golden knobs have been disconnected, pull the WiFi board out to the left.
    • Once the WiFi board is free from the device, remove completely.
Conclusão
Miguel Camarena
Membro desde: 01/24/19
367 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S2-G2, White Winter 2019 Membro de Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 581
