Ir para o conteúdo principal
Sony Vaio PCG-41216L Network Card Replacement
O que você precisa
  1. Sony Vaio PCG-41216L Network Card Replacement, Network Card: passo 1, imagem 1 %32 Sony Vaio PCG-41216L Network Card Replacement, Network Card: passo 1, imagem 2 %32
    • Flip the laptop over to begin the process.
    • Make sure the laptop is turned off and unplugged from the power cable.
  2. Sony Vaio PCG-41216L Network Card Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-41216L Network Card Replacement: passo 2, imagem 2 %32 Sony Vaio PCG-41216L Network Card Replacement: passo 2, imagem 3 %32
    • Remove the two 7mm Phillips #1 screws holding the battery cover.
  3. Sony Vaio PCG-41216L Network Card Replacement: passo 3, imagem 1 %32 Sony Vaio PCG-41216L Network Card Replacement: passo 3, imagem 2 %32 Sony Vaio PCG-41216L Network Card Replacement: passo 3, imagem 3 %32
    • Locate the networking card above the hard drive and next to the RAM.
    • Carefully pop out the two connection cables from the networking card.
  4. Sony Vaio PCG-41216L Network Card Replacement: passo 4, imagem 1 %32 Sony Vaio PCG-41216L Network Card Replacement: passo 4, imagem 2 %32 Sony Vaio PCG-41216L Network Card Replacement: passo 4, imagem 3 %32
    • Remove the black tape to uncover the screw underneath.
    • Remove the 3mm Phillips head screw.
    • When loosening the screw, the network card will automatically lift itself to a diagonal position. This is normal.
  5. Sony Vaio PCG-41216L Network Card Replacement: passo 5, imagem 1 %32 Sony Vaio PCG-41216L Network Card Replacement: passo 5, imagem 2 %32
    • Pull the network card straight out in the direction it is resting in.
    • Reinsert the new network card diagonally and into the same position as the previous one.
    • To screw the new network card back into place, you will need to push the network card back down onto the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 24
Ao todo: 716
