Ir para o conteúdo principal
Sony Vaio PCG-3C2L Hard Drive Replacement
O que você precisa
  1. Sony Vaio PCG-3C2L Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L Hard Drive Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-3C2L Hard Drive Replacement: passo 2, imagem 2 %32
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L Hard Drive Replacement: passo 3, imagem 1 %32
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L Hard Drive Replacement: passo 4, imagem 1 %32 Sony Vaio PCG-3C2L Hard Drive Replacement: passo 4, imagem 2 %32 Sony Vaio PCG-3C2L Hard Drive Replacement: passo 4, imagem 3 %32
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Place the laptop so that the bottom is facing up.
  6. Sony Vaio PCG-3C2L Hard Drive Replacement: passo 6, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  7. Sony Vaio PCG-3C2L Hard Drive Replacement: passo 7, imagem 1 %32 Sony Vaio PCG-3C2L Hard Drive Replacement: passo 7, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  8. Sony Vaio PCG-3C2L Hard Drive Replacement: passo 8, imagem 1 %32 Sony Vaio PCG-3C2L Hard Drive Replacement: passo 8, imagem 2 %32 Sony Vaio PCG-3C2L Hard Drive Replacement: passo 8, imagem 3 %32
    • Remove the hard drive by carefully sliding it out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 698
