Ir para o conteúdo principal
Sony Vaio PCG-31311L Motherboard Replacement
O que você precisa
  1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: passo 1, imagem 1 %32 Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew
    • These screws do not detach from the bottom plate.
  2. Sony Vaio PCG-31311L Motherboard Replacement: passo 2, imagem 1 %32 Sony Vaio PCG-31311L Motherboard Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to pry up on the plate and remove from device.
  3. Sony Vaio PCG-31311L Motherboard Replacement: passo 3, imagem 1 %32
    • Locate screw labeled "KB" and remove.
  4. Sony Vaio PCG-31311L Motherboard Replacement: passo 4, imagem 1 %32 Sony Vaio PCG-31311L Motherboard Replacement: passo 4, imagem 2 %32 Sony Vaio PCG-31311L Motherboard Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool tool to pry around the edge of the keyboard.
  5. Sony Vaio PCG-31311L Motherboard Replacement: passo 5, imagem 1 %32 Sony Vaio PCG-31311L Motherboard Replacement: passo 5, imagem 2 %32 Sony Vaio PCG-31311L Motherboard Replacement: passo 5, imagem 3 %32
    • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
    • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
    • Once the ribbon cable has been detached, lift the keyboard away from the device.
  6. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
    • Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
  7. Sony Vaio PCG-31311L Motherboard Replacement: passo 7, imagem 1 %32 Sony Vaio PCG-31311L Motherboard Replacement: passo 7, imagem 2 %32
    • Locate the LCD ribbon cable
    • Pull up and away from device to detach the LCD ribbon cable.
  8. Sony Vaio PCG-31311L Motherboard Replacement: passo 8, imagem 1 %32 Sony Vaio PCG-31311L Motherboard Replacement: passo 8, imagem 2 %32 Sony Vaio PCG-31311L Motherboard Replacement: passo 8, imagem 3 %32
    • Close and flip over laptop.
    • Locate the WiFi network card.
    • Use the plastic opening tool to pry up the two connectors.
  9. Sony Vaio PCG-31311L Motherboard Replacement: passo 9, imagem 1 %32 Sony Vaio PCG-31311L Motherboard Replacement: passo 9, imagem 2 %32
    • Locate the 6 screws on the bottom and remove.
    • Remove the final screw in the center to release the motherboard from the case.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler
Membro desde: 08/24/16
45 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-1, Lacy Fall 2016 Membro de USF Tampa, Team 1-1, Lacy Fall 2016
USFT-LACY-F16S1G1
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 1,550
