Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
Use a plastic opening tool to separate the bottom cover from the laptop.
Lift the lower cover and pull away from the laptop.
Remove the eight Phillips #00 screws from the battery:
Six 4.65mm screws.
Two 4.65mm screws.
Remove six 5.75mm Phillips #00 screws from the speakers.
Use a spudger to flip up the black latch on the four ZIF connectors.
Remove the four ribbon cables from the ZIF connectors.
Disconnect the speaker from the board.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Using tweezers, carefully unwind the speakers' wires from the plastic brackets holding them.
Where the wire is stuck under tape, gently pull the tape up until the wire is free.
Remove the speakers by picking the left and right pieces up and lifting them up and out of the computer.
Uma outra pessoa concluiu este guia.
