Ir para o conteúdo principal
Sony Vaio Fit SVF15N26CXB Speaker Replacement
O que você precisa
  1. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 2, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 3, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 3, imagem 2 %32 Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 3, imagem 3 %32
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 4, imagem 1 %32
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: passo 5, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: passo 5, imagem 2 %32 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: passo 5, imagem 3 %32
    • Remove six 5.75mm Phillips #00 screws from the speakers.
  6. Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 6, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 6, imagem 2 %32 Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 6, imagem 3 %32
    • Use a spudger to flip up the black latch on the four ZIF connectors.
    • Remove the four ribbon cables from the ZIF connectors.
    • Disconnect the speaker from the board.
  7. Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 7, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, carefully unwind the speakers' wires from the plastic brackets holding them.
    • Where the wire is stuck under tape, gently pull the tape up until the wire is free.
    • Do not remove the tape.
  8. Sony Vaio Fit SVF15N26CXB Speaker Replacement: passo 8, imagem 1 %32
    • Remove the speakers by picking the left and right pieces up and lifting them up and out of the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Althea McDavid
Membro desde: 02/14/18
857 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S2-G4, Nance Spring 2018 Membro de USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 523
