Introdução
The RAM is a small memory chip located within the device. This guide will show the user how to properly remove the Sony Vaio Fit SVF15N26CXB RAM memory chip. Use the project mat to keep the screws organized.
O que você precisa
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
Gently push the silver heads outwards on either side of the RAM chip to release it from the slot.
Pull the RAM chip gently out of the slot.
Uma outra pessoa concluiu este guia.
