Ir para o conteúdo principal
Sony Vaio Fit SVF15N26CXB Hard Drive Replacement
O que você precisa
  1. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 2, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 3, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 3, imagem 2 %32 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 3, imagem 3 %32
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32
    • Remove the four 3.20mm Phillips #00 screws from the hard drive.
  6. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 6, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 6, imagem 2 %32 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 6, imagem 3 %32
    • Use a spudger to flip up the black latch on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors and fold them over the hard drive.
    • Disconnect the hard drive and remove.
  7. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 7, imagem 1 %32 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: passo 7, imagem 2 %32
    • Remove the four 3.70mm Phillips #00 screws from the hard drive mounting case.
    • Carefully peel foil tray off of hard drive.
Conclusão
Althea McDavid
Membro desde: 02/14/18
857 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S2-G4, Nance Spring 2018 Membro de USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 1,189
