Introdução
The Sony Vaio Fit SVF15N26CXB has a flip screen that makes it different from a regular screen to remove. This guide will show you the necessary steps to take to replace the display. Use the project mat to keep the screws organized.
O que você precisa
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
Open the laptop and rotate the screen to the back side.
Remove the eight 2.85mm Phillips #00 screws from the back of the screen.
3 outras pessoas executaram este guia.
