Ir para o conteúdo principal
Sony Vaio Fit SVF14A190X Battery Replacement
O que você precisa
  1. Sony Vaio Fit SVF14A190X  Battery Replacement, Battery Replacement: passo 1, imagem 1 %32
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X  Battery Replacement: passo 2, imagem 1 %32 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 2, imagem 2 %32 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 2, imagem 3 %32
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X  Battery Replacement: passo 3, imagem 1 %32 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 3, imagem 2 %32 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X  Battery Replacement: passo 4, imagem 1 %32 Sony Vaio Fit SVF14A190X  Battery Replacement: passo 4, imagem 2 %32
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
Conclusão
Uma outra pessoa concluiu este guia.
Randal Crosby
Membro desde: 02/13/18
187 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S11-G3, Cheng Spring 2018 Membro de USF Tampa, Team S11-G3, Cheng Spring 2018
USFT-CHENG-S18S11G3
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 1,853
