Ir para o conteúdo principal
Sony Vaio Fit 13A SVF13NA1EL Screen Connector
O que você precisa
  1. Sony Vaio Fit 13A SVF13NA1EL Screen Connector, Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 1, imagem 1 %32
    • Flip over the screen
    • Remove all 8 screws as shown circled in the image using a Phillips #0
  2. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 2, imagem 1 %32 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 2, imagem 2 %32 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 2, imagem 3 %32
    • Flip the screen back over.
    • Use a plastic spudger to remove the top section of the cover.
  3. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 3, imagem 1 %32
    • Unplug the screen connecter from the back of the screen.
  4. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 4, imagem 1 %32
    • Disconnect the ribbon wire from the LCD connector by gently pulling it.
  5. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 5, imagem 1 %32 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: passo 5, imagem 2 %32
    • Gently raise the metal framework of the laptop to reveal the remaining portion of the screen connector.
    • Follow the ribbon wiring to where it connects to the screen.
    • Carefully pull the wiring to disconnect and click it back in place to reconnect.
Conclusão
4 outras pessoas executaram este guia.
5 comentários
Where to buy or to repair screen connector for Vaio Fit SVF13N13
Adham Ahmed - Responder
Where to replace the keyboard of Vaio SVF13N2
Arturo Dameno - Responder
Where i buy flexi
msobirin48 - Responder
The procedure is nicely explained
Is there an option to replace the LCD flet cable ... ?
It is complicated but we found a defect on the flet cable.
servis računara - Responder
I found some spareparts over the sony website. With all data from you laptop you can find them here https://uk.eetgroup.com/Guide/m/Sony-VAI...
Lukas Lutz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Duração total: 4,175
