Ir para o conteúdo principal
Sony Vaio Fit 13A SVF13NA1EL Battery Replacement
O que você precisa
  1. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement, Battery: passo 1, imagem 1 %32
    • Begin by turning the laptop top-down on a flat surface.
    • Use a JIS #1 screwdriver to remove the 4 screws circled in red
    • Use a JIS #0 screwdriver to remove the 8 screws circled in orange
    • Many of these screws are located underneath the rubber pads on the device.
    • Keep track of the locations of the screws removed for ease of reassembly.
  2. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: passo 2, imagem 1 %32
    • Use a spudger to carefully remove the back cover of the laptop.
    • Be careful when lifting around the ports and headphone jack to avoid causing damage to these components.
  3. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: passo 3, imagem 1 %32 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: passo 3, imagem 2 %32
    • Lift up back cover to access internal components of the laptop.
  4. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: passo 4, imagem 1 %32
    • Remove the screws in the circled areas using the J0 Screwdriver to release the battery.
  5. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: passo 5, imagem 1 %32 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: passo 5, imagem 2 %32
    • Lift the battery from the laptop to remove.
    • Replace if necessary.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 77
Duração total: 4,055
