Introdução
Replacing the battery in your Sony Vaio Fit 13A laptop is one of the easiest repairs you can attempt. With minimal technical knowledge you will be able to fix any battery related issues you may be having.
O que você precisa
Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
Locate and remove the ten 1mm Phillips #0 screws that are securing the battery in place.
3 outras pessoas executaram este guia.
