Ir para o conteúdo principal
Sony Vaio Duo 11 SSD Replacement
O que você precisa
  1. Sony Vaio Duo 11 SSD Replacement, SSD: passo 1, imagem 1 %32
    • Make a system backup!
  2. Sony Vaio Duo 11 SSD Replacement: passo 2, imagem 1 %32 Sony Vaio Duo 11 SSD Replacement: passo 2, imagem 2 %32
    • Using a spudger, remove the rubber screw covers.
    • Gently remove the speaker covers.
  3. Sony Vaio Duo 11 SSD Replacement: passo 3, imagem 1 %32
    • Use a sharp tool to lift up the laptop's cover
  4. Sony Vaio Duo 11 SSD Replacement: passo 4, imagem 1 %32
    • Remove cover
  5. Sony Vaio Duo 11 SSD Replacement: passo 5, imagem 1 %32
    • Remove all the screws. (Attention: these screws are different! Save them.)
  6. Sony Vaio Duo 11 SSD Replacement: passo 6, imagem 1 %32 Sony Vaio Duo 11 SSD Replacement: passo 6, imagem 2 %32
    • Remove the cover carefully. One side is attached with a short, flat, white cable. (Attention: Don't detach the white cable.)
    • Remove the screws (circled in red) and remove the battery.
    • When reassembling : Remember to hide the piece of plastic beside the battery (circled in the second picture) behind the plastic. Otherwise you will not be able to press the right mouse button.
  7. Sony Vaio Duo 11 SSD Replacement: passo 7, imagem 1 %32
    • Detach flat cable. To do so, you have to lift the black plastic bar, then release the orange ribbon.
  8. Sony Vaio Duo 11 SSD Replacement: passo 8, imagem 1 %32
    • Remove these screws to make it easier to remove the SSD.
  9. Sony Vaio Duo 11 SSD Replacement: passo 9, imagem 1 %32
    • The remove of the ssd
    • Remove the SSD (gently)
    • Replace the SSD ( it is a mSATA SSD )
    • Put back the screws and close the unit
Conclusão
25 outras pessoas executaram este guia.
Zero
Membro desde: 01/08/13
856 Reputação
Autoria de 1 guia
12 comentários
Mind BLOWING!!!!!!!!!!!!! Job, Bro..... It Helped me a Lot.....
Anwar - Responder
1TB ssd here I come!!!!
jamice4u - Responder
It worked! Can't believe it. I exchanged my 128GB one with a Crucial 500 GB one. Used the Acronis True Image that came with the new SSD. Still getting used to having so much free space :D
scorpiotide - Responder
Hi, I tried to upgrade to a 256GB SSD using shadowprotect and EaseUS to restore the image, but the drive would never boot. The SSD was not the problem as it worked fine when installing Windows from scratch. Did you simply restore a disk image with Acronis?
gps -
Thanks for this tutorial. I typically avoid working on my laptops and gadgets due to overwhelming hidden gotchas. This made swapping out my broken hard drive quick and painless. Thanks again!
Nathan Price - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 46
Duração total: 41,124
