Ir para o conteúdo principal
Sony VAIO VPCF 132FX Power Button Replacement
O que você precisa
  1. Sony VAIO VPCF 132FX Power Button Replacement, Battery: passo 1, imagem 1 %32
    • Remove all wires then flip the laptop
  2. Sony VAIO VPCF 132FX Power Button Replacement: passo 2, imagem 1 %32 Sony VAIO VPCF 132FX Power Button Replacement: passo 2, imagem 2 %32
    • Remove the battery
  3. Sony VAIO VPCF 132FX Power Button Replacement, Media Board: passo 3, imagem 1 %32
    • Remove the screws and flip it back.
  4. Sony VAIO VPCF 132FX Power Button Replacement: passo 4, imagem 1 %32 Sony VAIO VPCF 132FX Power Button Replacement: passo 4, imagem 2 %32 Sony VAIO VPCF 132FX Power Button Replacement: passo 4, imagem 3 %32
    • Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it.
    • Slide from the sides towards the center.
  5. Sony VAIO VPCF 132FX Power Button Replacement: passo 5, imagem 1 %32
    • Gently remove the wire of the Power Button.
  6. Sony VAIO VPCF 132FX Power Button Replacement: passo 6, imagem 1 %32 Sony VAIO VPCF 132FX Power Button Replacement: passo 6, imagem 2 %32 Sony VAIO VPCF 132FX Power Button Replacement: passo 6, imagem 3 %32
    • Unlock the Lock.
    • Unscrew the 3 Flat screws and remove the Media Board.
    • You may skip this step if replacing the Power Button.
  7. Sony VAIO VPCF 132FX Power Button Replacement, Power Button: passo 7, imagem 1 %32
    • Unscrew the Power button.
  8. Sony VAIO VPCF 132FX Power Button Replacement: passo 8, imagem 1 %32 Sony VAIO VPCF 132FX Power Button Replacement: passo 8, imagem 2 %32 Sony VAIO VPCF 132FX Power Button Replacement: passo 8, imagem 3 %32
    • While pulling the button upwards and towards the left (left fingers), push the button inwards (right fingers) at the same time to remove it from its place.
Conclusão
5 outras pessoas executaram este guia.
Marjorie
Membro desde: 12/23/13
2.273 Reputação
Autoria de 11 guias
4 comentários
My power on button was broken where the part you depress was detached from the little circuit board because the plastic holder was broke. Rather than buy a new switch assembly I simply lined everything up in the case and use a liberal amount of RTV to hold everything in place. The RTV is flexible enough to allow the plunger to depress the switch on the board and then spring back into place. It has work great this way since I fixed it six months ago.
Mark - Responder
I need a similar or identical part for my Sony VGN-TT130N notebook. Where can I find and purchase this power button assembly?
Gabriel Solnica - Responder
Did you ever find where to buy the part?
Gina Helton -
bonjour mon sony vaio led power vert ne allume pas mais pc marche bien .et ce que je peut active led pawer ?
mostafa chacha - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 55
Duração total: 13,604
