Introdução
This will guide you in replacing the Media Board of a Sony Vaio VPCF 132FX
O que você precisa
Remove the screws and flip it back.
you need to remove also all the screws from the bottom sides in order to detach the panel!
Uma outra pessoa concluiu este guia.
Um comentário
What are the functions of the media board? My vaio vgn-fw170j won't power up (no LEDS on the power switch, or anywhere else, no fan, nothing). Verified that MoBo has 19.5 VDC on the board. Replaced MoBo and CPU, still no response. Since power button plugs into Media Board, figured it might be failed - any idea if this could be the cause?
