Ir para o conteúdo principal
Sony VAIO VPCF 132FX Media Board Replacement
O que você precisa
  1. Sony VAIO VPCF 132FX Media Board Replacement, Battery: passo 1, imagem 1 %32
    • Remove all wires then flip the laptop
  2. Sony VAIO VPCF 132FX Media Board Replacement: passo 2, imagem 1 %32 Sony VAIO VPCF 132FX Media Board Replacement: passo 2, imagem 2 %32
    • Remove the battery
  3. Sony VAIO VPCF 132FX Media Board Replacement, Media Board: passo 3, imagem 1 %32
    • Remove the screws and flip it back.
  4. Sony VAIO VPCF 132FX Media Board Replacement: passo 4, imagem 1 %32 Sony VAIO VPCF 132FX Media Board Replacement: passo 4, imagem 2 %32 Sony VAIO VPCF 132FX Media Board Replacement: passo 4, imagem 3 %32
    • Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it.
    • Slide from the sides towards the center.
  5. Sony VAIO VPCF 132FX Media Board Replacement: passo 5, imagem 1 %32
    • Gently remove the wire of the Power Button.
  6. Sony VAIO VPCF 132FX Media Board Replacement: passo 6, imagem 1 %32 Sony VAIO VPCF 132FX Media Board Replacement: passo 6, imagem 2 %32 Sony VAIO VPCF 132FX Media Board Replacement: passo 6, imagem 3 %32
    • Unlock the Lock.
    • Unscrew the 3 Flat screws and remove the Media Board.
    • You may skip this step if replacing the Power Button.
Conclusão
Uma outra pessoa concluiu este guia.
Marjorie
Membro desde: 12/23/13
2.273 Reputação
Autoria de 11 guias
Um comentário
What are the functions of the media board? My vaio vgn-fw170j won't power up (no LEDS on the power switch, or anywhere else, no fan, nothing). Verified that MoBo has 19.5 VDC on the board. Replaced MoBo and CPU, still no response. Since power button plugs into Media Board, figured it might be failed - any idea if this could be the cause?
course2kid - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,382
