Ir para o conteúdo principal
Sony VAIO VPCEE26FX Keyboard Replacement
O que você precisa
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: passo 2, imagem 1 %32 Sony VAIO VPCEE26FX Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: passo 4, imagem 1 %32
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: passo 5, imagem 1 %32 Sony VAIO VPCEE26FX Keyboard Replacement: passo 5, imagem 2 %32
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: passo 6, imagem 1 %32 Sony VAIO VPCEE26FX Keyboard Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: passo 7, imagem 1 %32
  8. Sony VAIO VPCEE26FX Keyboard Replacement: passo 8, imagem 1 %32
    • Lift the keyboard up and away from the computer.
Conclusão
Equipe
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 Membro de UMass Dartmouth, Team S2-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S2G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 1,197
