Ir para o conteúdo principal
Sony VAIO VPCEE26FX Hard Disk Drive Replacement
O que você precisa
  1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: passo 1, imagem 2 %32
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Hard Disk Drive Replacement: passo 2, imagem 1 %32 Sony VAIO VPCEE26FX Hard Disk Drive Replacement: passo 2, imagem 2 %32
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: passo 3, imagem 1 %32 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: passo 3, imagem 2 %32
    • Using a JIS #0 screwdriver, remove the two 4mm screws securing the hard drive cover to the laptop.
    • Lift the hard drive up and out of its place.
    • The drive cover and hard drive are not pictured. They are both missing from this particular device.
Conclusão
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 1,843
