Ir para o conteúdo principal
Sony VAIO VPC-EB33FM RAM Replacement
O que você precisa
  1. Sony VAIO VPC-EB33FM RAM Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement, Battery: passo 1, imagem 2 %32
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM RAM Replacement: passo 2, imagem 1 %32
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM RAM Replacement: passo 3, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement: passo 3, imagem 2 %32
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM RAM Replacement, RAM: passo 4, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement, RAM: passo 4, imagem 2 %32 Sony VAIO VPC-EB33FM RAM Replacement, RAM: passo 4, imagem 3 %32
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
  5. Sony VAIO VPC-EB33FM RAM Replacement: passo 5, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement: passo 5, imagem 2 %32
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  6. Sony VAIO VPC-EB33FM RAM Replacement: passo 6, imagem 1 %32 Sony VAIO VPC-EB33FM RAM Replacement: passo 6, imagem 2 %32 Sony VAIO VPC-EB33FM RAM Replacement: passo 6, imagem 3 %32
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
Conclusão
Uma outra pessoa concluiu este guia.
Bret Omsberg
Membro desde: 01/14/13
16 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-39, Regan Winter 2013 Membro de Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
Membros da 5
Autoria de 15 guias
Um comentário
when i press the power button in VAio still black screen with little tick sound,
and one day i just turn it on and leave it for 17 hours and sadnlley it worked but when i tried to restart it it still not working with tick tick tick tick sound !!! any advise !!!?
dorii135 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 4,296
