Ir para o conteúdo principal
Sony VAIO VGN-FW 590 Keyboard Key Replacement
O que você precisa
  1. Sony VAIO VGN-FW 590 Keyboard Key Replacement, Keyboard Key: passo 1, imagem 1 %32
    • Open your computer.
    • Make sure the computer is turned off.
  2. Sony VAIO VGN-FW 590 Keyboard Key Replacement: passo 2, imagem 1 %32
    • Find the broken key.
    • The S key is our example though it is not broken.
  3. Sony VAIO VGN-FW 590 Keyboard Key Replacement: passo 3, imagem 1 %32 Sony VAIO VGN-FW 590 Keyboard Key Replacement: passo 3, imagem 2 %32
    • Insert the plastic spudger underneath the edge of the key.
    • Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
  4. Sony VAIO VGN-FW 590 Keyboard Key Replacement: passo 4, imagem 1 %32
    • Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
    • Press the replacement key firmly in the center until it is completely depressed and attached to the key base.
  5. Sony VAIO VGN-FW 590 Keyboard Key Replacement: passo 5, imagem 1 %32
    • Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
Conclusão
Congratulations! You have successfully replaced a key on your keyboard.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 1,481
