Ir para o conteúdo principal
Sony VAIO VGN-FW 590 Battery Replacement
O que você precisa
  1. Sony VAIO VGN-FW 590 Battery Replacement, Battery: passo 1, imagem 1 %32 Sony VAIO VGN-FW 590 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Battery Replacement: passo 2, imagem 1 %32 Sony VAIO VGN-FW 590 Battery Replacement: passo 2, imagem 2 %32
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Battery Replacement: passo 3, imagem 1 %32 Sony VAIO VGN-FW 590 Battery Replacement: passo 3, imagem 2 %32
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
Conclusão
Morton Wakeland
Membro desde: 10/30/17
101 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 799
